wheel caddy
harryc
has any one made a wheel caddy to assist us old geysers with limited strength in placing a wheel on the studs?
Northern tool has them.I've had one for over 35 years.I did a lot of truck work,and they make it easy to mount truck tires.I still use it for car and truck tires if I'm working on the ground and not on the lift.
It's a two man job, but I helped a guy change a van wheel by having him lower the jack very slowly until the studs lined up with the wheel holes. I had to clock the holes pretty accurately, but I was lucky and it worked out fine. He was older than me and I had lifting restrictions from the doc then. Not really practical for routine use, though. The Northern Tool wheel jack looks pretty good.
I am 83 and I install a wheel by lowering the car to just the right height to slide the wheel onto the axle. Get the lug nuts started & jack up the car so the wheel clears the ground. I use a battery powered impact wrench to tighten the lugs to 50 lbs-Ft in a star pattern. Go do it young man!
Locking the hub with a lug at the top will help align the original wheels, use your feet to raise the wheel as you sit on a milk crate . Lower the car to the height need to match your wheel seams harder than jacking the car up to the wheel height needed . V-8 wheels are harder to see the lug holes in the wheel, along the side of the road on a dark cold rainy night is the pits ! Call triple a !
Then there are the "Wheel Buddies" that I shared on another thread. Line up the two buddies with two holes and slide the wheel on. These are no longer made but I have seen similar on Amazon.
587006
i just use a bar, about 2' long, puts the wheel on easily, and no more tool to buy or keep track. I'm 89 years old but don't feel a day over 99.
