39-41 blocks are identical, you can make sure you have this block by the "pencil ledge" cast into the block just above the timing gear cover. You can actually put a pencil there and it will not roll off. 59 blocks do not have this ledge, just a flat surface and will also have a large 59 cast into the bell housing part of the block. As far as raised intake surfaces, I have three of these engines and two came out of trucks (took them out myself) both had a cam marked 5T and were not releived around the valves
