What water pumps do I need?
I'm putting an 8CM Merc in my '46 1/2 ton pickup. I need water pumps that will work with the wide belt and that will line up with the '46 engine mounts. The 59A pumps appear to be quite a bit different and I don't think they'll work on the 8CM. So exactly which pumps do I need? Thanks!
Yup. 8RT is what you need. I used them in a 40 Ford. Had them rebuilt by Skip Haney using the spiral impellors.
FWI, the 37 through 48 pumps will bolt up to the engine but they only work well when the whole front of the motor is converted to early style. This also requires the early style cam and gearing to work with the crab or rabbit type distributor. This mod is best done during an overhaul situation.
