spinelll
In reference to shaft end play, are we talking about when I grab a mounted water pump by the pulley (fan and belt in place) and move it towards the radiator and then back towards the block? Is that how you measure it?
When I measure that distance, I got like 1/16th of an inch! A response to a prior question stated that the max shaft end play is .006. But how can you measure .006 moving the pulley in and out in the manner mentioned above? Seems nearly impossible.
On a related issue. I replaced my fan with a "one piece" last year. Check out the picture below.
Can you see how the belt doesn't sit flush in the pulley? Is the powder coat on the pulley the cause? I also get this annoying squeak in that spot requiring a shot of WD prior to every ride. It bugs the bejesus out of me.
Thanks
Leo
Thanks
Leo
