C carpenter948 Junior Member Jun 13, 2014 #1 Hello, could someone tell me on a 1926 model T pickup what should we use in the grease cups for grease on the water pump. Thanks Neal in Iowa
redmodelt Well-known member Jun 13, 2014 #2 The rear cup by the impeller would/should get water pump grease; https://www.google.com/search?q=wat...:en-US:official&client=firefox-a&channel=fflb The front one by the pulley can use just regular grease.
Steve Jelf Well-known member Jun 15, 2014 #3 Then fix the cooling system so you don't need the pump, and use it for a wheel chock.
Willie in Houston Senior Member Jun 15, 2014 #4 Steve, I had to tell you but you are sounding more like Royce on the other forums. You might want to clean up your comments.
dumb person Well-known member Jun 15, 2014 #7 He was brainwashed from having it posted over & over & over.
