wanted, this model a fender bracket!
RodandInk
hagerstown
md
I need this front fender bracket for a '28 ford model A. These are the forged ones on only one year. One will work but two would be better. Send me a PM if you got any thanks...
We have both styles of 1928s like you have pictured. MOST forged 1928 front fender brackets use a larger diameter and longer bolt in the center mounting hole. The ones you have pictured are the less common ones that use all three bolts the same diameter. Also, FYI, the early 1930 braces use a nearly identicle bracket that has a different shape and the headlight bar holes are in a different location.
Steve @Bert's
www.modelastore.com
am i reading this correct ?
the '28 used that above and early '30 similar, late '30 and '31 entirely different, what then for '29 ?
i picked up some like these from a guy in pasadena,ca. he had a bucket full.
i got the rear braces too, but three holes to the side panel not two.
i don't know what fer, just need something to work.
if you're like me, prefer to restore 'em, i'd be happy to get you his number.
said he's clearing out all old A junk.
i have a single. readin forums, we may nee a measurement.pm if you are interested with measurements of holes. jus pm
Two different types of pressed steel front braces were used in 1929, two different stamped steel braces were used in 1930 in addition to the forged steel one, and three different steel ones were used in 1931.
