value of 37 heads
31chevy
Hi Barners, would someone out there know the value of 1937 21 bolt heads? they have been boiled out and magnafluxed. Ed Pitts a Barner member would like to purchase them. Neither of us have been able to find out their value. I used 34 heads on my 37 block with blockoff plates, this is why I have them. We would appreciate any info you can give us.
Thank you.
Gary.
Since many of these motors are now in earlier bodies with early heads, there are more than enough available. I would say that the cost of cleaning and maging is it.
I would say 75-100 if alum. less if CI. They also fit either side. [no left or rt to them] ken ct. for the pr.
Are the pumps in the head or in the block. For these heads. I have a set of heads that I am going to remove along with the block off plates. Changing to Skip Haney pumps. And center return heads.The radiator is mounted low on this shot rod(rat Rod) and the in the head pumps are the same or a tad. Higher than the water level. The pumps have a hard time taking suction. If the water level is a little low. I think with the lower mounted pumps this will solve the problem.I don't need the heads or block off plates. The pumps I promised to Skip. The pump Man.
