vacume brake
t-moss1
FORD did'nt put a gasket under the vacume brake plug but what do you Fordbarner's think about puting an o-ring or a gasket under it? THANKS
I use a plumbers fiber gasket from the hardware store.Take the plug with you as you call itand get the correct size.It will just slip over the threaded portion.There must be a seal there. "O" ring will not work.ken ct.
