Jack 34pu
My son is restoring a Cub Cadet and had carb troubles that sounded similar to Stromberg problems. It was always flooding - even worse when stopped. I checked it out carefully but found nothing out of place or adjustment. It seemed that the needle valve was not stopping the flow of gas , yet with it disassembled, the float worked wonderfully when I blew in the inlet and raised the float. It shut off the supply easily.
In frustration, I started to disassemble the carb one more time. The float seemed heaver than it should. I shook it near my ear and sure enough, there was a liquid sloshing around inside. I wipped it clean and no wet spots appeared. How could that be? Gas always seeps through even the smallest pinhole. How could gas get inside a sealed metal float?
I took the float home and got an idea. Heat the float and see what happens. I took a small heat gun (hairdryer would probably work) and heated the float while rotating from side to side. This is somewhat dangerous so be outside and wear face protection. All at once gas started spraying out like a shower head! Four small pin holes that where not detectable otherwise sprayed the offending liquid out until it was dry.
The float was too heavy with the liquid inside and would not quite shut off the fuel supply. Check out your Stromberg floats - you might be surprized as I was and solve a longstanding problem that was not visible to the naked eye. A little cleaning and solder and you will be back in business.
