Unusal Model A engine question
HCash
Just purchased a model A ford engine with an unusual gear driven cylinder on the carburetor side. The block is cast with an opening to accept the cylinder which has an oil line directly to the lower block. The engine serial number is
*RF3953* . can anyone identify what this cylinder or pump is for? Thank you.
Pictures are always good.
Picture of Model B block showing fuel pump mounting point.
Just a guess, but from your description the "cylinder" is possibly an oil filter screwed into an adapter attached to the timing gear cover on the carburetor side of the engine. The oil line you mentioned runs from the lower right side of the block up to it, correct?
Maybe a governor.
Oil filter is good guess also.
The number stamped RF#### engine blocks have turned up many times on the West Coast and all that I know of were Model B engines. Mine came out of a railroad track runner and some others were pulled from ann industrial stationary engine application. Some have claimed that the “RF” designation indicates replacement engines originating from the Richmond, CA assembly plant but I have not seen any documentation of that claim. Mine if stamped RF462# and is a Diamond block casting.
Thanks to all who responded. This is definitely a model A engine since no fuel pump but it may have model B internals. Thanks again all.
I will also say that it is a governor. Might be good for cruise control for long distance travel.
Model B internals - crank, mains, rods are much larger and won't fit in an A block without a lot of machine work (and loss of the strength advantage of the B).
What does the cylinder head look like?
That is definitely a Smith Compressor conversion. See that little bracket on the Carburetor?
They are very hard to find! Don't get rid of it. Is the head normal? post a picture of it.
