Only trouble with this method, I tried it, is you now have a freshly media blasted looking part on car.
I would suggest finding some bolts that were protected by caked on grease and washing them in solvent to study the original stamped out smooth finish.
Technically I suppose a blasted part is plain as you can get....but the surface takes on a "too bright" & overly consistant finish which is unmistakable as being blasted.
If your desire is to match a factory look you might consider picking the best hardware and solvent washing them, then use a mild phosphoric acid solution with a fine brush or fine steel wool to remove rust stains (rustmort by SEM company is my favorite)
The final colour can be further influenced by whether you
1)wipe the acid off and let dry.
2)rinse the acid with water and let dry.
3)or wipe and blow dry with comp air.
4)or rinse and blow dry with comp air.
5)soaking longer in the acid will sometimes effect the colour as well.
These are just alternate ideas to consider when you're trying to match the look exactly. You may very well come up with your own favorite method. Good luck.
