U Joint, Intakes, and more
barnstuf
Cape Cod
MA
Price
in ad
The following parts are used originals that I believe are OK for another life. Postage is additional. eMail Rich at barnstuf@comcast.net to order or for info.
Universal Joint, tight, NOT the riveted type, $35
Intake manifold with vacuum port, $25
Throwout bearing hub, $12
2 tooth steering upper race $15
Drag link, no internals, $25
Rear end center case $15
Timing gear front cover $5
Timing gear side cover $4
Water inlet on side of block $6
30-31 water outlet, gooseneck $8
Transmission reverse idler gear $20
Louvered clutch inspection cover $6
Non louvered clutch inspection plate 1928 $10.
