1928 Sport Coupe
I have a good U-Joint that I was told fit Model A up to 1938 Fords. I am working to rebuild the transmission and just wanted to verify it would fit. The side that goes to the main shaft is to big and turns on the shaft. The side that goes to the driveshaft looks the same, although I did not try it on a drive shaft spline. Does anyone have any idea what it may fit? It looks like a later Model A joint. When I laid a known Model A joint beside it I could see the difference in size.
I wound up rebuilding another u-joint with NORS parts I had on hand.
I have attached pictures with measurements.
Thanks
Thanks
Model A U-Joint maybe truck or V8 Standard Model A on the right unknown on the left 007.jpg62.9 KB · Views: 21 -
