Tudor sedan garnish molding question
MNFATS
I know the bottom sill garnish moldings are the same for '28-'31 Tudor side windows, but are the upper horseshoe-shape trim the same from '28-'31 as well? Thanks in advance for the info.
The bottoms are NOT the same. The notch on one end is just a little bit less. Off hand I don't recall if the shorter notch goes to the front or rear, but it will be evident when you try it.
