Transmission Drums rubbing
racemo
Here we are again! 1925 Coupe
Cleaned and inspected drums, bushings and gears. Bushings will get replaced.
I did notice that the low gear and reverse drum rub at the outer edge. Apparently, the thrust faces must be worn. What I'm thinking of doing is chucking them in that lathe and taking 0.020" off each mating edge. Any harm in that? I would think that the rubbing condition would create noise, add friction and put cast iron dust into the oil.
You thoughts please.
