Habusailor
If I go from automatic to 3 or 4 speed manual what is an easy fit for a newer ****** that will volt up to a 312 on my 57?
Don't know about the assist spring in a '57 but when I was in HS I changed my '65 Falcon from an automatic to a stick. The assist spring install took me the best 2 out of 3 falls. But I somehow was able to get it hooked up with only a minimal amount of blood shed and ample amount of 4 letter words. Fast forward 10 years or so and a mentor and boss did the same conversion on a '65 Ranchero. He stretched the spring on the bench by inserting washers between the coils. When he stretched it sufficiently he hooked it up and started removing the washers. I drove it several months later and was surprised when I pushed in the clutch and a washer dropped from under the dash.The under dash work is tough and that assist spring is a fun job. Look on eBay, you can probably find a set of pedals. I almost went 5-speed on mine but would have had to do some floor work on it.
