The tool kits were basically, just the basic tools needed to work on the model a. A crank, to crank start, a couple different sized wrenches, and a screw driver is basically what it amounted to. I wouldnt carry a ford tool set, because they are some what valuable, and i would just keep them in the garage. Go to the neighborhood hardware store and pick up a couple wrenches, both open end and closed. Get them all the way from 1/8 inch and up to 1 inch. That way you have everysize you could possibly need. then pick up a feeler gage, and bend the ends on the ones that are marked .018-.022 and .035. that way you dont have so search threw all the ones you dont need, when it comes time to gap points, and plugs. Next get a flashlight, couple different size flat head screwdrivers, plyers (both kinds), gloves, file, test light, adjustable wrench, hand crank, and anything else you want to add. This should all fit in an old bank deposit bag that you can just throw in the floorboard, tray behind the seat, or just the back seat.
