Thought the vacuum nipple on the Ford adapter would just thread into the port on the distributor just like in the vid posted above, but not so lucky. Was thinking of cutting off a portion of the original vacuum line from the distributor to the carb, but then remembered that I got a few of the original Ford vacuum fittings from Charlie in NY. Then fabbed up a line from some 3/16” brake line I had lying around. Also used one of the adapters from my hand vacuum pump kit from the hard brake line to the hose going to the machine. Hope it all works.
