Fred A
Out dirving in nice weather today when the car stalled quite suddenly when pulling into a busy intersection. I was about twenty miles into the drive at this time and the temperature was were it always sits with the 180' thermostats. It had been running a bit rough, seemingly dropping cylinders at fast idle, but power seemed normal, running kind of sloppy like when a power valve fails. I have not been able to restart the car since and have looked at all the classic points of failure. The accelerator pump pumps normally. The sediment bowl has been catching lots of rusty water and mud which gets stirred up from "testing" the new brakes. Replaced the carb anyway There is some spark however less intense than would have been expected. Replaced the coil with the ugly one that was running the car when I got it 4 years ago. Still the spark is unimpressive. The condenser is one of those original looking things with few miles of service. Since I dislike working on these distributors and the '47 is the most unfriendly to rewire, fear is that the coil wire may haver backed out inside the cap, such a crush of wires. hate those things. Either starting spray did nothing. Bypassed the ignition resistor. Still not even a pop out of the engine when trying to start. Voltage to the coil aroung 4v static. Plugs look wet, from trying to start? Been intending to find someone to set new points in the distributor. Did I say I dislike those things, especially where they are located behind belts and down in a hole... Not used to working this hard just to get something started. I know there are catastrophic things like timing gears that can make diagnosis even tougher, but this engine is too fresh for that kind of stuff, or is it? Any ideas? Thanks: Fred A
