Stromberg EE-1 Carb Base Casting
cbillelder
Greeley
Colorado
Price
$30
For sale is a Stromberg EE-1 base casting assembly that came off a '34-'35 Buick carb. Now, before you scroll back, this base WILL FIT ON 97 and 48 carbs, and will give you a TIMED VACUUM PORT that the 97 and 48 bases don't have. This is important if you plan to run a Chevy or other conversion distributor on your flatty, as the manifold vacuum won't give your distributor the correct signals. The base is in good condition and all parts move freely. You will need to change out the throttle shaft as the linkage arm is different. This is the perfect piece for that center carb on your 3-2 setup. Price is $30 plus shipping. Questions? Call Bill at 970-330-6958 or email cbillelder@comcast.net
