frank long island
ok i installed a 6 blade steel flex fan shroud new radatior flushed block new hoses and its still running hot 203-208 at t stat housing at idle
where do i go next
as of now i'm not running a t statDid you replace the T-stat? It may be hanging up and not letting the coolant flow completely. If you did what temp are you running. I may get flamed for this, but I've never had good luck with flex fans.
frank you need to run a thermostat without it the coolent is flowing too fast thru the rad to cool ...
I've read in a couple places that running a 160 t-stat won't let the engine get hot enough to burn out any condensation that may be in the engine which can have negative affects on the oil. I plan on running a 180, that should keep it around 185-190. Which I think they were run @ 192 from the factory if I remember right.
