Habusailor
I have a 1957 Fairlane 500 with a 312 engine. It ran good a few weeks ago when I went to start it yesterday it seemed as though the battery was dead. I put the charger on and it acted like the battery would not take a charge so I installed a new battery.
Then I tried to start the car but it will only run with the ignition switch in the start position. Could it be the resistor block, or ignition switch? I also put a bushing in the shift linkage to take out some play, could the neutral switch be out of adjustment?
