Trying to locate hole for the bolt that holds speedometer clamp on 29 coupe.
Is the speedometer clamp attached to the upper flange of the frame or lower flange?
If it is the lower flange - there are two holes between the rear motor mount and the center cross member. Which hole is it (one closest to center cross member or one closest to firewall) ?
If it is the upper flange - there are 3 holes. 2 close together (that would seem too close to the center cross member) and one additional hole. Which hole would it be?
