Smallblock Ford tri power******SOLD******
Dick's Hot Rod Place
Franklin
Indiana
Price
1325.
Well, here is an item that is not that readily available to the SMF crowd. This 3x2 unit started it's life as a late model fuel injection plenum base, which by the way, is perfect for this application, and a new 3x2 top plenum box was added. After all machining and assembly the intake unit was coated with powdered aluminum under satin fuel proof clear, which makes the intake assembly look brand new with that fresh sparkley finish on new intakes. On top of that is not your "Daddy's 94's" These are the bigger 2110's with the larger throttle plates, venturi area, late model annular spray bars, and more vrrrrm than their baby brothers. The linkage is progressive, using obsolete arms from loooooong ago, and the fuel rail is a cast EELCO unit with specially prepared hard lines. Also, satin smooth air cleaners. All the items on this unit are flattened to a degree making it kinda "stealthy" lookin', eh? Everything redone, and ready to rumble.
Fits 221, 260, 289, and 302.
****************************SOLD**************************
