dmaxweb
I need to replace the bushings in the 2 tooth steering sector housing. In the suppliers catalogs the bushings have an oil hole in the side which they say must be aligned correctly.
The bushings in there now have the helix oil grooves and I understand which end should be pressed in/out but they do not have a hole. There is no grease fitting in the sector housing. Should there be one?
I know I could buy a rebuilt sector housing with needle bearings for $50 but new bushings are are only $5.
