running hot update
frank long island
got back from york and carlisle and harbor freight with my thermo scan thermomator started the old 55 merc let it idle for 45 mins. gauge moved between 3/4 and hot :eek: shot the temp of the thermostat housing it read 160:rolleyes: shot the rad it read 140 :D shot the heater hose at the firewall 125 ;) still no thermostat should i replace it also added a shroud and am adding a flex fan this weekend guess its time for a gauge replacement thanks for the imput
For some unknown reason, Y block temp senders are at the rear on the head. Yes, it will give you a clue, but I want to know the temp right at the thermostat. That should be the hottest place in the system. In all the years I have messed with 54's and 55's, if the dash gauge is anywhere near the actual engine temp, its just a accidental.
I would replace the gauge and put the thermostat back in. The shroud is a good idea as well, As for flex fan be careful which one you get preferably not aluminum.
This is running hot??????
