pjdeb
Novice here. When I took the engine apart on my 1923 coupe I noticed that the number 2 rod cap had been X and a dipper pipe had been installed. I would have expected that to be the number 1.
None of the other caps had been X or drilled.
On closer inspection I noticed that the "number 2" had the factory markings of 1.
What was in "number 1" actually had the factory markings as 2. Should I put the back in as I found them or should I switch them to the factory markings?
The engine had been overhauled before. Not many miles on it since then. Sat for 30 years.
Your opinion on which way to put the caps back on?
