Finally got the rear end set up with the new gears,
As on the old one ,it needed .020 to get the pinion depth as per the etching on the pinion (4.375), then another.020 to get the pattern as per the run in mark on the new gears, then backlash set at .005,
I ended up with a very nice pattern and good backlash,
to do the second gears was way quicker as I knew what to do and how.
the test drive turned out to be really quite and smooth, did about 20ks on it today and are really happy
My take from this exercise ,take note of the pinion depth etching on the new repo gears, and start from that,
I will do an article for our club mag on this later.
Lawrie
