Removing Timing Cover Tips
all american boy
Fordy's
while i'm patiently waiting to
get the harmonic balancer puller
and manual on cd,
i thought of this question.
how about some tips on getting
timing cover off?
Have A Nice Day!
remove radiator , fuel pump and viberation damper, unfasten cover from block and pan, water pump stays on cover, you might tear the pan gasket when removing cover, if you do you have 3 choices, make a new piece that goes on the front of the pan and cover, use a product called gasket maker to repair the gasket or use it to make a new front part of gasket, or remove the pan and replace the whole gasket, i have done the first two and have had good results
If you buy a front cover gasket set, it will have a new cork pan gasket to cover just the front, the big cover gasket, and a new front seal. These covers have no dowels to locate it. Put the new seal in, put the cover on loose, install the damper well oiled to locate the cover in the seal, then tighten the bolts.
ordy's
what about cam parts?
nothing is going to fall out when
i take off timing cover?
FYI: this engine is on the ground.
loose. not in a vehicle.
has been all along!:)
Have A Nice Day!
Fordy's
here's pic.
have to get dampener off before
proceeding.:)
Have A Nice Day!
There is a bolt holding the cam gear on. Keep the spacers and washers under that bolt in order. Lay them out and take a picture.
don
i've seen a few post's around about y blocks
and it looks like a can of worms.
something about 'thrust washers' and
a retainer plate.
i sure will take pic's if i want to take it out
before manual gets here!:)
getting timing cover off and cleaning it
will keep me busy for a good while.
Have A Nice Day!
There is nothing scary about working on y blocks. They are a very simple and uncomplicated engine. They are very much like any other ford v8 before they started going aluminum and/ or overhead cam with computers controlling everything. The thing with the y block is that it saw the start of a great line of overhead valve engines. It got left behind because people thought it had limited performance potential. How wrong they were when you look at the achievements of Ted Eaton. Who ever thought that you could get 500HP+ from a street able Y.
Enjoy.
Regards
mr 55
i had to come up with my one tip!:)
i will make sure all the timing cover bolts
are out.
then knock on it with a 2 x 4 until
it breaks loose.
same as taking bellhousing off of
my little Fordomatic FX.
Have A Nice Day!
