35 v8 Deluxe 5-window coupe with rebuilt (Schwalm's) engine.
After diagnosing a faulty fuel pump (later 59a design with the glass bowl), I bought a rebuild kit, and also bought a fully rebuilt 59a pump on the e of bay.
Mind you, this is my first fuel pump rebuild, but I did my homework, watched the videos, read the forums and took things carefully.
The first problem I encountered was that the new diaphragm was made incorrectly (the shaft is not aligned properly). Luckily, I had another bellows that was in good shape. The press-fit check valves were another story, but I ultimately replaced them safely as well. I replaced the bowl filter and seal. Finally, I replaced the arm and spring (the original arm had very little travel distance with the diaphragm).
After carefully (and evenly) tightening everything back together, the pump still didn't work!
Thankfully, the rebuilt original (MACS part) I bought on eBay worked without adjustment.
Any ideas what I might have done wrong? Any sources to rebuild or purchase an original 59a pump? I see there are new reproduction fuel pumps, but they don't look right (starting with those Phillips head screws!)
Thanks in advance
- Paul
Thanks in advance
- Paul
