Radius Ball
petew
Can anyone tell me the proper measurement spec for a radius ball ?
Mine has a rubber ball on it . I want to pull it apart and measure before deciding how to proceed.
The ball is 1-1/2 inches in diameter.
Stick the ball and the bottom of the wishbone in hot (maybe boiling) water for half an hour - you should be able to get the rubber ball off without ruining it.
You may find the rubber ball was a "quick fix" for a ball worn in the original configuration, or you may find the original configuration has been "upgraded" by a previous owner leaving the original ball nearly intact.
Repair is best done with a "hollow ball" pressed on and tack welded in place. Others sell a "loose ball" you cut off entirely and carefully position and weld back on.
Some particularly artful weldors "build up the ball" and grind back down to the 1-1/2".
And others put the rubber ball back and keep driving....
I've used both the original and the rubber ball and see no appreciable difference in driving/road handling - provided it's a "tight" connection.
Joe K
"You may find the rubber ball was a "quick fix" for a ball worn in the original configuration, or you may find the original configuration has been "upgraded" by a previous owner leaving the original ball nearly intact".
Joe K it appears you were correct.
I took the rubber ball off ,measured the radius ball with a caliper and got 1.470 top to bottom and side to side so still a circle and only worn .015 on each side.
Had a new original style ball mount kit that I put on with plenty of grease and went for a ride.
The results were that a light shimmy I had when coming to a stop was gone and I swear it steers better .
Petew, I may be off. If so, others will correct me, but I seem to recall that a light shimmy as you are coming to a stop is sometimes uneven braking on the front.
Have you checked for free play in your bearings, spindle bushings, toe in, etc?
Now the downside of the original - take it down annually and check condition. Technically the brass/copper part will wear first, leaving the ball nearly intact.
Ford did a lot of design engineering anticipating "after-care." That was the machinery world they lived in (think "sight feed lubricators.") Not like today at all with our "greased for life" existence.
There is a general aphorism lurking around those last two sentences somewhere. I'll be derned if I can figure out where it applies to life and where it can be overlooked.
I don't think I'm alone in the conundrum.
Joe K
Well the change back to the original ball and mount did away with the little shimmy that had been present. It’s all gone now .
I made a radius gage and will be be welding and grinding the shape back
