Lyndon
I thought I might chime in on this one.
I went through a similar problem on my '36 LB engine earlier this year. Just before first startup, with the spark plugs out I spun the engine over on 12v to check for oil pressure using an analog gauge. I got zero pressure this way. So off came the intake manifold, the pressure relief valve was intact, and no oil was flowing out the hole on the bottom of the clutch/flywheel area of the pan, so the only thing left was the front galley plug (or a dud rebuilt oil pump)?? I removed the distributor cover, and drilled a small hole in the timing gear about where the plug should have been and lo and behold NO PLUG. After installing the plug (and a certain amount of swearing later) the engine had something like 30-40 psi oil pressure at idle.
I am very glad I resisted the temptation to 'just start'er up and run it a while' to see what would happen. Those connecting rod bearings were very hard to come by in that engine!
