Question 1924 frames
toms32
Question 1924 Frames - Does anyone know if the 1924 Model T truck frame is the same as the sedan Frame. I have an opportunity to purchase a panel delivery body and I need to know if it will fit on my coupe frame. thanks for any help on this. Also is the coupe and the sedan frame the same ? confused :confused:
If your panel delivery body was built for a TT frame ,it will not fit. All car frames were essentially the same from 1914-25 and then 26-27 are the same. HTH.
TT frames were much more heavy duty on the rear part. The very front of the TT frames were very similar to the car. The engines for trucks and cars were the same.
The front axle was the same as the car with the exception on an extra leaf or two in the springs. Everything to the rear of the firewall is different.
