les harris
New member
I have seen a post about pp finger measurements can someone tell me what they are measuring and how ? I thought all you have to do was bolt the pp to to the flywheel evenly I did that and the fingers would not release with the throw out bearing fully retracted. I made sure it worked while I had it on the floor but when I installed the motor and trans as one unit I had no pedal after one push on it the pp hung up. I took the pp and tested it on my hydraulic press and it worked now I am at a loss as what to do to make it work.
