steve fritz
Installing a power steering set up on 54 Mercury, 256 y-block V8.. There is a hose bracket that the two large p.s. hoses run through from the pump down to the control unit. Exactly where does this bracket mount to?? Looks like it mounts with a 5/16 bolt that clamps the two hoses into a rubber grommet to secure them.
If anybody has a 54-56 Ford or Merc with a y-block V8 with original factory power steering, I'm sure yours would be the same. Thanks for any info on this.
