one good reason not to do this..... You are in "minnesota" and you know how the weather changes.
First thing in the morning gives you less wind, that is good. But gusts of wind that you normally would not notice will take the paint away before it hits the car. You might be lucky and not get any bugs but that is not likely. Temps change quickly from cool overnight to warm/hot in the morning so you have a small window of opportunity to get the temp that will be compatible with your thinner. You could be painting for an hour and temps can change a lot in that time. First coats will dry slow and last coats will dry fast, sometimes too fast to flow out. By the time you get around the car to the beginning again, the paint at the join line has dried too much to flow together. And shooting in direct sunlight is an impossible situation. Instead of a good gloss you will get something that can look like sandpaper. Painting in part sun and part shadows will be even harder. You are taking a real chance trying to do this outside. I would not attempt to do a whole car outside even under the best of conditions.
If you have a space at least 12' x 18' inside you can do a paint job on a model a. Three feet on each side and four feet front or back will be tight but it can be done. I painted many cars in a 12' x 20' garage in the late 50's. I will have to admit that i had to nudge the car forward and back to get the room to paint each end, but they do roll easily enough. Stretch painter's plastic sheet across the walls to protect other stuff in the shop and put a good vent fan in a window or door opening to blow out the fumes. You don't want to do this every day, but it can be done. Be sure to wear a paint suit, nitrile gloves and a proper paint mask.
The inside setup will give you still air, reasonably consistent temps and controlled drying. And a much better paint job.
