I just got finished putting in new hydraulic hoses in my 1926. I bled the brakes and everything worked. Then I pushed on the pedal again and then I saw fluid coming out of the front drum brakes. I thought the bleeder screw or hose going to the wheel cylinder was loose. No such luck so I took the drums off and found the wheel cylinder had blown out. Some fluid got on the drum brakes. Here is my question do I need to replace the drum brakes? I know the answer is yes but I had to ask. The drum brakes didn't get saturated I pulled the drums off right after I saw fluid leaking.
Thanks
Jerry
Thanks
Jerry
