Joe AZ Senior Member May 28, 2010 #1 Is there anything to consider when fitting the newer style Melling oil pump to a '36 LB engine? I'm assuming adapting the oil pan for the pick-up etc.? Thanks, Joe
Brian Well-known member May 28, 2010 #2 Use the 8RT pickup, and remove the baffle in the pan if it has one. Easy as!!! Brian
