This '55 T-Bird has an automatic and there's lots of room around the oil pump.
If the car is a stick shift there will be a clutch pedal cross-shaft and linkage next to the pump.
Three bolts hold the pump onto the block, 1 on top, 2 underneath.
A rubber sleeve seals the pick-up tube into the pump housing.
The oil pump drive shaft from the distributor and camshaft may come out with the pump, I don't remember.
