German guy
Is there a recommended torque for the oil pan bolts. I will be pulling and cleaning out the pan, and adding a filter as soon as my barn is warm enough that my fingers will not freeze.
Also...I keep reading posts for and against using silicon sealer. When I added a 6.1:1 head I began seeing a bit of oil mist coating the underside of the pan...possibly the result of 'blow-by' forcing oil out of the seal...but over 350 KM of driving and the oil looks brand new with no noticeable loss....so not sure. My predecessor used silicon sealer instead of a proper gasket so it is possible that when I re-install the pan with the right gasket the mist will disappear. Opinions?
