Looking for a tee that Ford used, it has a .050 restrictor hole.
1/8" male npt for the filter side.. 1/4" female npt for the sender.. 1/4" inverted flare fitting on the tubing
Hi, I just pulled one out of an old 8BA filter canister. Threads are all in good shape, had the oil sender in place, and part of the line coming out of the other connection so everything was protected. I cleaned it up should serve for another fifty or sixty years. Call if you need it at 802-869-2688 or e-mail at jen.toby@yahoo.com Thanks, Toby Lampert
