Jack 34pu
Had engine and trans out and back in a few times to fix a trans problem. Marked flywheel and pressure plate to reinstall as they were originally. Same clutch plate. As I go up thru the gears and pass 1800 rpm, I get a shudder/vibration and a jangling sound underneath. It passes very quickly. It also happens as I slow down or change gears - but always at approx 1800 rpm. How could something be suddenly out of balance?
