Mystery Head
Branded
I’ve acquired a V8 head but have to clue as to what its origin is. There’s no markings other than the cylinder location stamped 2-5-7-8 near each spark plug hole. There’s no markings is also one other threaded hole in the head for each cylinder. Anyone have any idea what this head might be from.
My thoughts are early caddilac by the look of the water neck outlets and the cylinder numbering, but its just a guess.
I’ve acquired a V8 head but have to clue as to what its origin is. There’s no markings other than the cylinder location stamped 2-4-6-8 near each spark plug hole. There’s no markings is also one other threaded hole in the head for each cylinder. Anyone have any idea what this head might be from.
568639
568640
Correction cylinders number 2-5-7-8 was going from memory guess my memory is not what it used to be. I correct it in first post also.
GM style numbering -so probably Cad. Ford is 1,2,3,4 down one side. Right? Newc
Correction cylinders number 2-5-7-8 was going from memory guess my memory is not what it used to be. I corrected it in first post also
The "combustion chamber" configuration looks pre-Ricardo; nothing contemporary, that's for sure.
I think it's around a 27 Cadillac what i found looks the same. Hole beside spark plugs maybe compression release or add little gas to cylinder maybe.
That's it. I even looked up Cadillac's but I didn't go back far enough I guess.
