I have a gauge attached to the outlet side of the regulator to set pump pressure. ChatGPT suggests hat possible problems could be a plugged filter, restricted fuel line, or blocked tank vent.
- Weak pump output or low voltage at the pump.
- A restriction or malfunction in the regulator.
The best way to separate pump trouble from regulator trouble is to measure pressure before the regulator while watching the existing outlet gauge. If inlet pressure also collapses, look upstream. If inlet pressure remains healthy while outlet pressure falls, suspect the regulator. I will put a pressure gauge on the inlet side and see if it drops.
