modern distributor
djredfox
Im brand new to the hobby i have an original untouched 28 roadster not a bit of rust or damage. So what advice as to which modern distributor to get.Im am switching over to 12 volt system
Thank You
David
This is the "to the editors" section. You will get the best response to your question in the "general discussion" area, "Model A". By the way you don't need to change the distributor just because your changing to 12 volts.
