Model T Rear Spring
All the ones I've seen, both tapered and later, are 2". You didn't ask, but TT rear springs are 3". Front springs are 11/2".
The rear T spring length is 43 1/2" more or less. Except the '09-'16 wide-track rear spring. That one is longer.
Except as noted the unsprung length should be about the same for all years, the crown height would be different lower for 26-27
