model a doodlebug
rogerkb1936
port orchard
wa
1930 based model a doodlebug. this ran and operated fine before i sold the engine. 4 speed trans has all gears, AA ring and pinion rear works fine. gas tank and radiator do not leak. i ran this around for nearly an hour after i got it, with no problem. rear tractor tires are new, 36" high. the wheels had stud holes welded in and then was professionally redrilled to AA pattern. nice seat installed. asking $225, tires are worth more than that. roger at 360 674 3130
It is soooo frustrating how nice your doodle is, the cheap price & how far you are away from Pennsylvania. Up until 3 mos ago, I had been looking for a doodle for 2 yrs, finding $1000 rustbuckets at the end of every lead. I eventually found mine 4 hrs away in Maryland, but it was just what I was looking for, albeit at $1,400! I'll post a pic of what that $ buys on the east coast... Good luck with your doodlebug!
Do you have the steering column and wheel? Are the brakes operable? Any ignition/gas line parts?
