J jerrod1932 Senior Member Jul 18, 2010 #1 im using a model B engine, does anyone know if the model A throw out hub (this is the cast hub that holds the throwout bearing,) is the same for the model B as is used onthe model A? THANKS
CWPASADENA Well-known member Jul 19, 2010 #2 When using a Mobel B engine with a Model A transmission, use the Model A Hub. With a Model B or V-8 Transmission, use the V-8 Hub. Chris
