Main bearing not so good
dave in australia
Last weekend, coming home from Melbourne on a club IMAD run, as I slowed down from 80 Km/h (50 Mph), to 50 Km/h (30 Mph), my engine started to make a loud thump noise. I nursed the car home, and thought it was a rod big end bearing. I was wrong, it was the rear main. I don't know if the goldish colour on the cap is a bronze repair, or babbitt discolouring caused by heat.
I can't tell for sure by the photos but it may have been a layer of brass shim stock cut to fit in there. Folks used to put shoe leather and all sorts of stuff in the bearings to get them by for a little longer. Babbitt is generally thicker than whatever that is in there. It comes out in chunks when it breaks down.
Looks like it lost oil
It could be that area was brazed in a attempt to have the Babbitt bonded to the cap
If it was brazed, they didn't do anyone any favors. If it had a brass shim stock installed with a hole drilled or punched for the oil flow, slippage would block the flow.
It takes a lot of heat to braze a part. It would melt any babbitt that was ever there. The melting point on babbitt is lot lower than brass.
That is a '28 rear main cap and those are forged steel and not cast iron like the later caps.
The steel caps are quite tinnable and would not require a layer of braze in order to attempt tinning prior to pouring. I think you are just looking at the remans of a bearing that got really warm from a lack of lubrication. Most likely the oil supply got cut off and the bearing got hot enough for the babbit to melt and start wiping.
Dave, You are lucky you made it home. I am very happy for that but I am not happy about the condition of your engine.
