i remember back in the fiftys we lowered our 39-48 fords with lowering shackles on the rear spring are the still being made if so buy what company? thanks al
Lowering shackles should be used with sway bar. go buy some cold roll flat stock 3/8" x 1 and make your own using your stock shackles for pattern. use a small square file to square up the hole.
